how do I install a short ram intak 08 accord...??
Hi need hel on knowing how to install a short ram intake in a Honda accord 2008. Please links would be good help thanks
Re: how do I install a short ram intak 08 accord...?? (PurpleAccord88)
Honestly, do not know, but I would assume it is similar to the older models. See if K&N, AEM, or INjen offer a product. Basically eliminate the resonator from under the fender, strip out the intake tube, re route the vacuum tubes and you're good. I did this on my old ACura 00 CL, very easy. Great improvement in mid torque and gas. I would also research to see if the Accord engine is used on any acura and look up on the Acurazine site- awesome posts and good DIY's.
Note: any tim eyou make mods affecting the engine, you shoudl unpolug the negative battery cable for a few mts and then restart to reset the CPu to adjust to the modified performance. My old CL had CAI, dropped Eibach 1", racing pulleys. Quiet a difference. best of luck
My Name is Nobody
Re: (imsickofrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice »</TD></TR><TR><TD CLASS="quote">why would you make a 08 accord short ram intake ? it comes with a cold air intake... </TD></TR></TABLE>\
i put a filter of a 96 stock inegra filter to the stock rubber hose and removed the whole stock filter box of the my accord !
