How to access 2010 Accord EX blower?
I want to spray a cleaner into my AC condenser, which is starting to smell (I did just replace the cabin air filter, so it's not that.) The cleaner I intend to buy instructs the user to spray it in through the blower motor hole: "Klima-Cleaner is applied by removing the blower fan and inserting the supplied spray tube through the intake vent which leads directly to the evaporator."
Where is the AC blower located? I've never accessed one of those before...
Re: How to access 2010 Accord EX blower?
The blower motor is above your feet on the passenger side of the car. There are three 8mm bolts holding it in place, you may have to remove a plastic access cover to see it.
With the correct tools it should take no longer than 5 min to pull out and put back in.
Another thing you can do is spray that stuff in the cowl area (the area the wipers are parked in) On the passenger side where there are some venting holes, this leads to the blower housing area in a round about way.
dingusjt
11-13-2003 02:10 PM
VTECAcuraGSR
04-13-2003 10:31 AM
