For honda techs
For honda techs
have any of ya deal with the issue on the v6 misfire cylinder #3. And after doing the update and replacing the plug. In the past three months i have done about three accords and one oddesey tech line recommends to replaced the valve seals and inspected the top of the piston on cylinder #3. i have to replaced the seals and replaced the piston rings on the same cylinder. So my question to ya is if ya have deal with the same issue and do ya think that would finally fix the problem one's and for all.
Re: For honda techs
I would have to agree. If compression is good that would mean no reason to rering a motor. have you done a valve adjust? if they are to tight on that cylinder would throw off map sensor readings.
hondachris1994
11
03-02-2008 03:23 PM
