Honda Crosstour engine codes
Engine light just came on pulled into a advanced auto
codes came up P0420
with other codes 61-11
18-14, 83-12 and 16-14 can not find these codes what do they mean
codes came up P0420
Re: Honda Crosstour engine codes
P0420 is "Catalyst system efficiency below threshold" (Means the engine computer has determined there is a difference between your upstream and downstream 02 sensors that is out of range, it uses input from the two sensors to cross-compare and determine if your catalytic converter is working)
61-11 is for the SRS system (Means there is a problem detected in the operation of your seatbelt buckle) Gotta buckle Up! I have read a few things saying it may be covered under a Honda lifetime warranty, usually consists of replacing the buckle receiver.
18-14 is for the ABS and/or the VSA system
83-12 is for the ABS and/or the VSA system
- Failed Catalytic Converter
- Failed Downstream 02 Sensor
- Major Exhaust Leak
- Faulty Downstream 02 Sensor Wiring
jason h.
02-22-2013 04:06 AM
