Honda Canada - Converter Issue
Problem:
I was told by a Honda dealer that if I install an aftermarket exhaust converter that I will have problems when I do the emissions test( only in Province of Ontario). Specifically, only the Honda original converetr will pass the test.
This does NOT make any sense at all to me, as it fringes on the edge of being unlawfull.
Anybody have any expereience with replacing exhaust system and passing the emmissions test?
All feedback much appreciated.
CK
CK
Re: Honda Canada - Converter Issue
keep the honda one on get the test then swap them out.. keep keep the old one if the next time u test it u pass ur good u fail replace with oem,., rinse and repeat lol
Seagull Management
Aftermarket *should* pass. Sometimes they don't in california, but California is ridiculously strict. I have an uncle in Ontario and IIRC he basically said if you fail so many times they give you some sort of conditional pass anyway.
Aftermarket cats are a lot cheaper because they have less material in them. Hence they don't work as good. That makes passing an emissions inspection iffy. If it won't pass try the O2 sensor trick: http://www.civicforums.com/forums/22...l?ref=esp-link
LoL. Wut? Why?
