Help! please
Help! please
Car: 2000 Accord Engine: H23a Vtec Blue Top ECU: PCB Location: Wisconsin
Ok for some reason I can not get this engine running right with car.
It is blowing white smoke than after awhile it is blowing light grayish/black. I put coolant and bleed it. What is the cause?
It also sat out in the winter so moister built up, I see it coming out of exhaust no coolant smell.
My Name is Nobody
Re: Help! please
is it loosing coolant?
generally, white smoke means(water) a head gasket has blown... but that needs to be confirmed using a compression test and or a consistent loss of coolant.
if you are replacing coolant, my vote is a blown head gasket.
Mikey Hernandez
13
05-01-2014 07:33 AM
