Heavy oil consumption in '03 Honda Accord - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 09-01-2013, 06:34 AM   #1
Default Heavy oil consumption in '03 Honda Accord
Hi, everyone!
So I have a 2003 Honda Accord EX 2.4L I4 with automatic transmission. I'm just short of reaching the 150,000 mile mark.
I've had the thing for a couple months and overall I love it. I have had to have quite a bit of work done to replace the timing chain, the motor mounts, and starter, but now that all of that's been done, it seems to be running great.
The only thing I've noticed now is that the thing is using oil like crazy. The consumption rate is probably 1 qt. every 1000 miles. I've seen places on the internet where some say this is normal consumption for this vehicle/engine with high mileage. But can that be possible? That seems like a buttload of oil to me.
I've had the car checked at my local import mechanic for leaks (whom I've known for years and trust) and he said the engine looks clean/no leaks anywhere. The car doesn't smoke at any time or doesn't run roughly. It passed a compression test with flying colors. There is no evidence I can find to point to where the oil in the car is going.
Anyone know what this could be? Is this a problem that could get progressively worse or is it just normal aging? I CANNOT afford to put any more money into this car, so if you guys think it will be something expensive to fix and it needs to be fixed, I will most likely sell it.
Thanks!
thomasc93 is offline   Reply With Quote
Old 09-01-2013, 06:48 AM   #2
Default Re: Heavy oil consumption in '03 Honda Accord
There is a PCM update for oil consumption.... But they sometimes don't work. How long do u go between oil changes? Why was the timing chain replaced? Was the vtc done at the same time?
Racer02gtstang is offline   Reply With Quote
Old 09-01-2013, 06:50 AM   #3
Just for giggles, have you replaced the poor old PCV? When you replace it, watch out for the little washer.
Lost Again is offline   Reply With Quote
Old 09-01-2013, 07:28 AM   #4
Thanks for the replies, Lost and Racer!
I have not replaced the PCV. I actually thought about this, but would the PCV be causing it to burn that much oil?
Between oil changes I typically do it every 3000 miles, which is usually every 2-3 months. Or if I haven't gone 3000 miles in 3 months, I'll go ahead and do it around the 3 month mark.
The timing chain was replaced after the computer threw the P0341 code around the 147,000 mark. The dealership determined the timing chain stretched and replaced it. That cost around $1300. I'm not sure they actually did anything to the VTC. I think they checked the timing to make sure everything was running correctly, but I don't think they actually did any work involving the VTC.
Again, thanks for the responses!
Old 09-01-2013, 07:46 AM   #5
Quote:
YES. If really bad even more.
96 accord - oil loss jc164800 Honda Accord (1990 - 2002) 8 05-29-2011 05:58 PM
Trying To Fix Oil Consumption Need Another Opinion D16SohcVtec Honda Civic / Del Sol (1992 - 2000) 14 02-07-2011 07:11 AM
major consumption preludin Honda Prelude 2 10-14-2008 05:37 PM
Oil Consumption Question cats_on_ice Honda Accord (1990 - 2002) 27 04-02-2006 10:57 AM
? '88 Accord LX, rough idle and sudden high oil consumption zavalo Honda Accord (1990 - 2002) 11 02-02-2003 11:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
