Front Door and Dash Speaker Replacement
Does anyone have a detailed procedure for replacing the front door and than the dash tweeters?
I need to know how to take apart the interior door panel to access the 61/2" speaker and than also the in-dash tweeter.
Thanks!
Thanks!
Re: Front Door and Dash Speaker Replacement
there are four screws that need to be removed first. there are two that are near the bottom middle, right above the spaces where you can put stuff in. there are also two hidden ones. the hidden ones are by the inner door handle. they are blocked by a plastic flap which can be removed by a flat head. remove these screws and then remove the corner plastic piece near the corner of the window and the top of the inner panel. this is just pulled off. then unscrew the door lock rod by twisting it. then take a flat head of something less sharp and wedge it in between the metal of the door and the plastic of the inner panel. starting at the side and working towards the bottom and all around. you can't do it at the top. you will hear the inner panel "snapping off" the frame of the door and then once it's all popped off, pull the entire panel upwards so it can get out of the window socket area. and it's off, but will be attached by lights and door handle cord so you have to detach those to actually seperate everything from each other.
