Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Dumb AC Evaporator core question
Old 06-07-2014, 04:44 PM
psymon1116's Avatar
Default Dumb AC Evaporator core question
I've been having issues with my AC for the past 8 months. It used to always blow freezing cold air. It eventually started getting warmer and warmer. I took it in to have refrigerant put in bya friend who knew what he was doing and had all the tools to make sure it was charged . After about 2 months it started blowing hot air again. Refilled it with refrigerant with sealer and everything was good for about 3 weeks. Decided to have my mechanic check it out, explained everything and we put in refrigerant with UV dye to check for leaks. Put it in and ran the system, grabbed a black light and started checking all the visible connections. Couldn't find a single leak. He told me it could be the evaporator. So today I took apart my glove compartment and managed to get to the evaporator without breaking anything. Only problem I can't figure out how to get the evaporator out. I took out the screw that holds the suction line and receiver line bracket to the firewall but I don't know how to disconnect the lines.
Old 06-08-2014, 05:20 AM
Lost Again's Avatar
Default Re: Dumb AC Evaporator core question
A year of the car would help.......some other minor details might help more (how many doors, number of cyl's).
Old 06-08-2014, 07:12 PM
DCFIVER's Avatar
Sealant likely caused more damage than it fixed. Who knows what the original issue was,but you now have sealant in there and youre gonna have to replace everything to ever get this system working right.....
Old 06-09-2014, 02:09 PM
psymon1116's Avatar
Sorry, 2003 Accord 4 cylinder coupe
Old 06-09-2014, 04:58 PM
Lost Again's Avatar
I'm not one to get into the BS - sorry that I'm stupid and just try to help.
So you removed the "bolt" under the hood that holds the two line to the evap - are you having issues getting those lines off the evap or something else?
bainz610
09-03-2010 05:30 PM
gqstatus05
08-20-2009 11:31 AM
slammin86
03-09-2009 01:45 PM
Serdar
07-08-2005 06:23 AM
xrupertx
06-28-2004 03:47 PM
Quick Reply: Dumb AC Evaporator core question
