Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
DIY Manual transmission fluid
Old 09-03-2009, 02:56 PM
ch0baca's Avatar
Default DIY Manual transmission fluid
Any DIY's on how to change MTF? I still can't locate the filler bolt...i can only find the drain bolt
Old 09-06-2009, 02:10 AM
conker's Avatar
Default Re: DIY Manual transmission fluid
I assume the 05 6MT is the same as the 06. That being the case, the fill is almost directly below the medial edge of the air-box on the top side of the transmission. About the size of a dollar coin with a square cut-out. You will need a 3/8 socket extension. It uses the drive itself so no socket is required. I found it easier if I pulled the air-box cover so I could move the intake ducting out of the way. The fill amount in the manual was about dead-on for me.
Old 09-06-2009, 01:55 PM
ch0baca's Avatar
ooooooooo ok dats much better, so i would need to move the intake box for better accessibility?
Old 09-27-2009, 03:55 PM
1badteg's Avatar
https://honda-tech.com/forums/showth...smission+fluid
rollercosta123
01-16-2021 01:10 PM
Nicholas Bailey
Transmission & Drivetrain
05-23-2016 09:11 PM
professorman
01-23-2015 09:50 AM
Ryan111987
Honda S2000
15
07-15-2009 07:45 AM
Heat
09-07-2005 12:10 AM
Quick Reply: DIY Manual transmission fluid
