Disconnect ABS
Disconnect ABS
I read the post about disconnecting the ABS by pulling the main relay/fuse for an 05. Can someone tell me if its the same for an 03?
The pump is broke on mine -the brake pedal will not go down, there is so much back-pressure. Just by pulling the relay/fuse, the ABS won't work but the reg brakes will be fine?
Thanks
Thanks
Re: Disconnect ABS (honda53008)
sounds like your brake booster isnt working properly, no vaccum assist at all? is it impossible to put down the pedal? or is it like old manual brakes on the older vehicles?
____________________________
More Tips on : Tough Country
