Difference between 03-07 Accord / TSX rear disc brakes
Looking for an upgrade on my 05 Accord drums. I'm considering the TSX if the application is interchangeable.
I'm also considering an upgrade from a Pilot. Can any recommend where to source brackets?
Re: Difference between 03-07 Accord / TSX rear disc brakes
Brackets are gonna be the hardest part
i am going with Acura RL Calipers, 350Z Rotors, custom Brackets, powdercoated and using OEM Rear powdercoated as i've heard just with the Fronts...the stopping power is amazing
TL Type S or RL is what most use...not sure about TSX...Pilot for the Rears is what i heard is a good choice
in regards to the brackets, they can be custom done (expensive) or buy pre made ones for around $100-150ish i believe
best of luck!
Attachment 513770
best of luck!
Attachment 513770
Thanks for the info and your opinions on the RLs. I'm only looking to replace my rear drums so I can run Goodridge ss lines on all corners and for aesthetic purposes.
I believe I'll just go with the rear 12" kit by FastBrakes.
Since I'm swapping from drum to disc, will I have to get a rear disc e-brake cable?
N1 Andy
06-16-2007 05:23 PM
TypeSH
02-05-2003 08:38 PM
