Curious Problem -- 2004 Accord Won't Start - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 08-05-2010, 05:30 PM   #1
Default Curious Problem -- 2004 Accord Won't Start
Hi,
My 2004 Honda Accord 4-door sedan LX will not start -- I think it may be a problem with the immobilizer or low voltage on the battery. I took a video of what is going on; check it out here on YouTube.
HTML Code:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/nHqGq8f_zpM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/nHqGq8f_zpM&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I am using the valet key, which is all I have and has never given me problems.
The car has always run fantastic. I drove it to lunch and back today with no problems, but when I came out 4 hours later it was doing this. All maintenance has been performed.
We are tight on money right now, so any help and advice is appreciated!
MSteven1980 is offline   Reply With Quote
Old 08-06-2010, 08:18 AM   #2
My Name is Nobody
MSchu's Avatar
Default Re: Curious Problem -- 2004 Accord Won't Start
I wish I knew more about the 04's.... have you tried a new battery or Jump?
what does that little green Key symbol on your dash represent? Does it mean good key recognition or does it represent a bad key recognition?
MSchu is offline   Reply With Quote
Old 08-06-2010, 08:30 AM   #3
That does look like a bad battery or bad battery connection
1grex is offline   Reply With Quote
Old 08-06-2010, 08:42 AM   #4
GoLowDrew's Avatar
Quote:
X2.
Check the CCA on your battery. It should be at 400-500. In the 300 range, it could be hit or miss.
It may be good to power the lights, but not enough muscle to turn the engine. The way the dash dims, make me think that.
GoLowDrew is offline   Reply With Quote
Old 08-12-2010, 06:17 PM   #5
KWayRacing's Avatar
Definitely battery/battery cable connection related. Video is sweet.
KWayRacing is offline   Reply With Quote
Old 09-21-2010, 04:59 PM   #6
same problem, replaced battery, got alternator and starter checked not problem, starts fine one day and not the next. whatever it is, its killing my battery, it wont even allow it to start when being jumped.
beehonda04 is offline   Reply With Quote
Old 09-22-2010, 04:45 PM   #7
DELuth's Avatar
Assuming the battery cables were checked properly, you need a starter.
The key has nothing to do with your problem.
DELuth is offline   Reply With Quote
Old 02-23-2012, 04:39 PM   #8
I am only assuming that there is a short somewhere. Mostly like in your battery, starter or alternator cables. I also had somewhat the same problems,
I thought I'd share. It wasn't any of the cables, it was my key. The Key remote came of the key and I was trying to start the car with only the medal part and it won't. I had to put the remote back on the key for it to start. So it won't start when key is not whole I guess. I guess another thing to look at is the condition of your key... I hope this helps anybody....
2004hondaaccord is offline   Reply With Quote
Old 02-29-2012, 04:53 PM   #9
Quote:
Have you done a parasitic draw test to determine if you have something pulling power from the battery during key off conditions? That video definitely looks like you have low battery voltage.
justinsbg is offline   Reply With Quote
Old 04-11-2012, 06:54 PM   #10
I am pretty sure Honda had a service bulletin for this issue. If I recall it was #01012005 requiring the replacement of the fuel pressure regulator and maybe a PCM update from the dealer.
Maverickz is offline   Reply With Quote
d16zc/z6 mini problem. need help chrysanderson Honda CRX / EF Civic (1988 - 1991) 25 11-01-2010 09:31 AM
Need a form check on Power Clean and Squat please cityofcaterpillars General Discussion and Debate 6 10-16-2009 06:25 AM
Say What? Private insurance can't do what? 914Racer General Discussion and Debate 13 07-21-2009 04:27 PM
Best chinese ever! XViEtBoiX General Discussion and Debate 80 02-28-2009 09:16 PM
2009 R1 Sound Clips fatboy01 Honda Motorcycles 1 01-26-2009 08:56 AM
Tags
04, 07, 2002, 2004, accord, green, honda, key, problem, problems, recognition, start, starting, symbol, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
