Confused about wheel fitment/bolt pattern
Looking to buy some new wheels for my '07 Accord 4DR, I think I found the ones that I want to go with but almost every eBay listing that has them does not list the 2007 accord as being compatible, even though the bolt pattern is the same (I believe these cars use 5x114.3). Am I overlooking some kind of important specification or should these fit just fine? This is my first car and I am a total noob when it comes to wheels and tires
http://www.ebay.com/itm/17x7-Vision-Cross-5x112-5x114-3-5x4-5-48mm-Gun-Metal-Wheels-Rims-Inch-17-/400752741579?hash=item5d4eb98ccb&vxp=mtr
Re: Confused about wheel fitment/bolt pattern
Please don't take this the wrong way.....if you spend a little time on one of the sponsors web sites you might find the answer to your question.
"tirerack dot com"
"tirerack dot com"
Took a look and I'm still not entirely sure, the bolt pattern is the same, stock offset is 55mm I believe and these wheels are not far off (48mm) so from what I've read it seems like they should fit just fine but I want to be certain before I blow a ton of $$$ Which is why I came here
BrianDelSol
08-12-2005 10:27 PM
