Changing miles to km on odometer
Hello..I'm moving to Canada.
I have 2005 Honda Accord EX and in order to import this car in Canada
They have few requirements:
1. Change miles to km on odometer.
2. Daylights on car
Can you guys help me out how can I change odometer to read km instead of miles and how do I activate daylights on my car. I would really appreciate your help in this..!!
Thanks in advance.
2. Daylights on car
Thanks in advance.
Re: Changing miles to km on odometer
You could order a used gauge cluster from Canada, that way the speedo will have the KM/h larger than the MPH and the odometer would read in Kilometers. On the DRL's not sure.
1. A different instrument cluster may be needed to change miles to km; and if you wanted to keep similar mileage/km, a trip to a Honda Cananda dealer to see if they will rewrite the odo data with HDS on a used cluster.
2. To have DRL; possibly to make it work, you may need to add the DRL relay in the muti-relay box in the engine compartment. There should be a multi-relay box in the engine compartment for only two relays, on the US model, the one DRL relay should not be there.
markysparky
02-06-2006 06:55 AM
