CEL where is the plug and what pins to jump to pull code
Hey guys… trying to help out a buddy of mine. Need to find out where the ECU is and what pins to jump so I can pull the CEL code. By the way, I owned a 2000 sedan on steroids. thanks, i appreciate the help~!
Re: CEL where is the plug and what pins to jump to pull code (Chiovnidca)
Is the DLC the OBD connector under the dash? and if so then can you point me in the right direction to decode what the flases mean?
thanks!
thanks!
Re: CEL where is the plug and what pins to jump to pull code (nafreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nafreak »</TD></TR><TR><TD CLASS="quote">Is the DLC the OBD connector under the dash?</TD></TR></TABLE>
No, cause I am still unsure if this is the correct connector to be jumped.....
Hard to miss the DLC. Yeah, it should be under the dash.
And, it looks like the one in that pic (narrows toward the bottom; 16 pin connector).
SOHC4life 96
36
04-03-2005 08:39 AM
