A/C low side pressure excessive
Hi all, very nice forum here, this is my first post and I'm hoping you can point me in the right direction.
My mom has a 2003 Accord LX, 2.3L. Her AC is not working. I checked the low side pressure with a cheesy charging gauge and it was very high--perhaps 90-100psi.
The fans operate correctly. The compressor clutch does not engage--I would guess because of the over-pressure switch (assuming one exists).
Her AC was overhauled about 2-3 years ago and had functioned quite well up until recently. It has not been serviced since then, so I am ruling out an "overcharged" situation.
Tomorrow I will rent a set of manifold gauges and try to get some accurate high/low side numbers. Should i also try to manually engage teh compressor clutch by attempting to tap it? If it does engage does that mean that my problems are just a clutch gap that is too wide?
Any other advice would be appreciated!
Thanks in advance for any help!
Re: A/C low side pressure excessive
So, ambient temperature is 87 degrees. Low side measures 78psi, high side at 110 psi.
Tapping on the clutch did not cause the compressor to engage.
