Broken door handle
Broken door handle
The drivers side door handle on my girls car stopped working from the inside. Is there any trick to popping the panel off to take a look? Im not used to working on hondas that arent 15yrs old
its a 2003 4door
its a 2003 4door
My Name is Nobody
Re: Broken door handle
nope... you got to get in there from the inside to take a look. the newer gens SLIDE into place from the outside by sliding foreward
the inner handle is whats giving me the problem...would you happen to have a pic of that page?
i dont see any obvious bolts holding in the door panel, does it just use poppers?
My Name is Nobody
I don't right now... and that one above is from the 08 car. But I am sure it is very similar in layout.
You may be looking at three or four Philips head screws around the armrest handle area and an electrical connector on the inner side of the door panel. The Panel simply pulls away from the door, try starting in different place on the pan... mine starts easily when I begin pull from the bottom front edge.
If you're car's armrest has cups in the hand hold area, you may need to pry up a cover using a scribe tool or small screw driver
My Name is Nobody
Sure... In most cases you will see a tiny bracket that holds a actuating rod... the rod end or bracket cap will have broken off. it s a very simple repair with basic tools.
the cable snapped where it attaches to the inner door handle. Thinking of having her drop it off at honda. I cant really see **** in there where the other end of the cable is and i can only get one hand in to feel around. looks like 27 is the cable that snapped but honda lists like 4 different things under 27 with the same name but different prices...
suhteevin
01-06-2009 09:04 PM
