Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Battery light burnt out - effect on charging
Old 01-16-2018, 09:31 PM
martik777's Avatar
Default Battery light burnt out - effect on charging
My bat light came on and I determined the alternator was bad. Haven't replaced yet but I noticed the bat light is no longer working, even on the bulb check position with the ignition key.
Question is, will the new alternator charge with a burnt out battery indicator bulb?
Old 01-17-2018, 04:27 PM
Global Moderator
tech8's Avatar
Default Re: Battery light burnt out - effect on charging
What year vehicle and model?
Yes, an alternator will still charge with a burnt out charge indicator bulb. There is the possibility the charge indicator LED is not burnt out though.
Old 01-17-2018, 05:26 PM
martik777's Avatar
oops, 2003 accord 2.4l
I replaced the alternator and now the light is working as is the alternator. I guess the voltage regulator or diodes were causing the light not to work after about 100 miles.
Luckily I noticed the light before it went out.
Old 01-17-2018, 05:47 PM
Global Moderator
tech8's Avatar
Good to hear thing are okay now.
Generally, the voltage regulator sends a L signal ground (indicator lamp circuit) to the ECM/PCM, where the ECM/PCM would then provide the ground (-) to turn the charging indicator lamp ON. Power (+) to the charging indicator lamp comes from under-dash Fuse No. 21. When the alternator sends charging voltage to the ECM/PCM, it turns the charging indicator lamp OFF.
Old 01-17-2018, 06:26 PM
martik777's Avatar
So, the old alternator voltage regulator was probably failing those last few miles? Brushes were moderately worn but I doubt that was the problem.
Thanks for the explanation.
88hondaspeed
06-14-2011 09:34 AM
Mychal71
08-11-2006 04:27 PM
zcivicz
15
05-03-2002 07:03 PM
Quick Reply: Battery light burnt out - effect on charging
