Anti Theft Question
Anti Theft Question
Hey all,
I have a 2004 Accord V6. My problem started when I would lock the doors with the key fob, and the lights or horn would not chirp (no matter how many times I pressed the button). I thought nothing of it, I still used the key fob to the lock the doors, and now what happens is that the factory alarm goes off for no reason. (horn goes nuts and lights flash). What would cause this, and are they related? I have checked the door jamb switches, and they seem to work fine (when you open/close the door, it is indicated on the dash, and the dome lights go on/off), so I am pretty sure they are fine....I hope. ANY help would be great. Thanks
ALSO, I don't think it would be related, BUT, I do have a HID kit installed in the car. No wires were cut. Just plug and play. That is the only mod to the car, everything else is stock.
Re: Anti Theft Question
I never thought of that. My wife ditched the car about a year ago, and the front bumper was ripped off, among smaller front end damage. Also, I remember shutting the hood one day, and then this started, was back under the hood, shut it, and then it worked for a bit. I'll check it out and post results. Thanks.
No, the Anti-Theft is factory. It is the hood latch/switch. I unplugged the connector at the hood switch, and tried it. Everything is back to normal. With the connector unplugged, the car thinks the hood is shut (switch closed). The only thing is that if someone opens the hood with the factory anti theft set, the alarm will not go off, but I have a new hood latch/switch. That goes in tomorrow. Thanks for the help.
borrego_cd5
08-14-2011 05:05 PM
