Accord EX remote won't open trunk - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 05-04-2010, 03:05 PM   #1
Default Accord EX remote won't open trunk
The trunk on my 06 Accord Ex will no longer open when using the remote key. The remote works and the trunk sounds like it wants to open, but the cable doesn't seem to move enough to release the trunk. I've also tried applying pressure while holding the button but the trunk won't release. The trunk will open when I use the latch on the driver's side door.
Anyone have any thoughts on how to fix it?
Thanks in advance!
Jack Straw is offline   Reply With Quote
Old 05-06-2010, 03:08 PM   #2
H22PwrdInspire's Avatar
Default Re: Accord EX remote won't open trunk
Even though it may sound like its operating, the trunk actuator could be going bad and not getting to the fully open position when you are using the remote, thus causing it not to open.
H22PwrdInspire is offline   Reply With Quote
Old 05-06-2010, 03:47 PM   #3
Quote:
Thanks for the response.
Any idea how difficult it is to fix and/or replace? How much would a actuator cost?
Old 05-07-2010, 09:42 AM   #4
PowerUser's Avatar
Shouldn't be too hard. IIRC a couple 10 or 12 mm bolts is what's holding it in there. Not 100% sure what the cost would be. Call your local dealership and see
PowerUser is offline   Reply With Quote
remote starter peterng Tech / Misc 0 11-02-2015 10:21 AM
Beep alert won't shut off. Help/advice please. TCups Honda Accord & Crosstour (2003 - 2012) 2 05-21-2012 07:03 AM
Install trunk pin switch for 2002 Civic??? cpncpn Audio / Security / Video 1 05-16-2011 06:18 PM
Honda civic 2006 ex- trunk issues vwj79 Honda Civic (2006 - 2015) 11 01-16-2009 06:49 PM
Trunk Lid STUCK! GuCCi_GSR Acura Integra 7 05-20-2007 11:43 AM
Tags
02, accord, acura, door, doors, honda, key, odyssey, open, opens, remote, rremote, s2000, solenoid, tl, trunk, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
