Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
ABS, Brake and TCS stay on - all other lights are out
Old 12-17-2012, 07:44 AM
Greg Ryan's Avatar
Default ABS, Brake and TCS stay on - all other lights are out
Got in my 2003 honda accord yesterday and the dash is completely dark except the TCS, ABS and Brake light which stay on all the time. Speedometer doesn't work - it's stuck at 0 mph and the RPMs are saying 1,500 at all times. It's been raining like crazy here for about a week straight so I'm wondering if water might of gotten into something which is causing the TCS, ABD and Brake light to stay on?
I'm guessing a burnt out fuse is causing the rest of the dash to be dark. But I do find it interesting that certain lights on the dash work - the TCS, Brake, ABS and the blinkers all work.
I don't want to put more the $50 into this car as it's on its way out. Also the fan doesn't work anymore so I have no heat or a/c.
Old 01-24-2013, 04:05 PM
LadyAntler's Avatar
Default Re: ABS, Brake and TCS stay on - all other lights are out
I just had a problem with my ABS light and found it to be the brake switch stop pad. Got a replacement for $3.68 at the honda dealer, fixed the problem. No more lights on dash problem :-)
Old 01-28-2013, 06:46 PM
AMCCPO's Avatar
Was your lights fix on dash?
Old 03-01-2014, 09:08 AM
bEAR2's Avatar
I had new tires put on my car. When I left the lot, the triangle and TCS light came on. took it back but they did nothing. Another shop told me they must have disconnected the wheel sensor. 1 st shop ssays everything is connected. Honda dealer wants $80 per wheel to check it out. Where are the wheel sensors?
Old 03-01-2014, 10:37 AM
My Name is Nobody
MSchu's Avatar
Why would ANYONE in there rightmind disconnect the receiving sensor when getting a set if new tires... More than likely theymighthave forgot to reinstall the senors back on the rims if they took them off for some reason
dannetech
11-20-2011 03:59 PM
IncaEM2
Honda Civic (2001 - 2005)
10-15-2007 02:57 PM
jamesjarvis85
09-13-2007 11:45 AM
UK PRELUDER
01-22-2006 09:15 AM
ThumperAC
08-31-2005 03:56 PM
Quick Reply: ABS, Brake and TCS stay on - all other lights are out
