5w-30 good for K24A4?
PM Garage
Re: 5w-30 good for K24A4?
yeah would work just fine its the same weight 5w but it works at a different temp range if I am correct I though I did the same thing to my old honda fit I felt the differences it might have been mental. If anything you might get less gas mileage but you probably will not notice. From what I understand Honda switch to 5w-20 because of improved gas mileage and better and tighter clearance in engine specs. If you have a choice stick with 5w-20 and buy it at WalMart. FYI the Honda insight runs 0w-20?
From your other thread:
https://honda-tech.com/forums/showpo...7&postcount=10
I'll say it again castrol syntec is some good stuff!
Now if you really want to research oil I'd reccomend reading up www.bobistheoilguy.com.
5w20 GTX is fine to use on your car as well.
Once again if you really want to learn more about oils and oil filters I'd check out http://www.bobistheoilguy.com/
Check out that site and read through their forums. I've learned a ton more then I thought I would about oil.
Topshot
Honda Insight & CR-Z Hybrid
62
06-04-2011 04:44 PM
2004es2
Honda Civic (2001 - 2005)
11
06-25-2007 05:26 PM
