2011 Honda Accord Shaking
Hi, I have a 2011 v6 4-Door Honda Accord with around 73k miles. For some reason when accelerating between 70-90 the car shakes pretty badly when accelerating. Under 70 and from 90-120 the shaking goes away. The steering wheel also vibrates/shakes from 70-90. Oil was just changed but I think after reading other forums a wheel/tire alignment would be what I need. Any input would be great. |
Re: 2011 Honda Accord Shaking
Check wheel balansing to
I can't say for sure if balancing your tires would fix the issue because I never drive that fast. But I would recommend you getting the tires Road Forced Balanced if you plan on traveling at those speeds.
Check for cupping or uneven wear on the tires. replace the tires before you pay for an alignment.
