Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2010 Accord J35Z3 swap into 7th gen?
Old 09-08-2018, 07:21 AM
AndyD's Avatar
Default 2010 Accord J35Z3 swap into 7th gen?
Hi all,
I am doing some research but not having much luck finding any solid information on my swap project.
I just picked up a 2003 6-spd V6 coupe. The previous owner blew the clutch on it and a neighbor offered to help replace it. Well, after diving into the job, he found out how hard it is and gave up. He left the car in a major state of disrepair. It needs several things done to it so I figured now is the best time to replace the whole engine and install a better one.
If you have InstaGram, check it out at leftfordeadcars
I found a local 2010 6-spd swap locally. He has the whole drivetrain. Engine, trans, ECU, and wire harness available.
Based on my research, I found one person who said one of the sensors on the J35Z3 is in a different location than the ones found on the J30A4/J30A5/J35A8. The J35Z3 and J35A8 seem to be pretty similar but with a few differences. I don't put too much stock in the HP numbers Honda claims for their engines but the J35Z3 is reported to have 271 hp 10.0:1 compression ratio and the J35A8 286 hp 11.0:1 compression ratio. Based on those differences, I am assuming the cams and pistons are the main difference. Maybe even the valve sizes.
I am hoping if I have the 2010 J35Z3 engine harness as well, this will solve all of the problems. So my question is, if I have the whole swap, will everything bolt up and wire up plug-and-play? Do the engine harnesses match up perfectly?
Any information you can provide is greatly appreciated!
AndyD is offline
Old 09-16-2018, 07:07 AM
Freedo_Civegra's Avatar
Default Re: 2010 Accord J35Z3 swap into 7th gen?
If you can find the 2010 accord wiring info, I can help. Iíve got all the wiring info for the 2003-2007 accords.
Freedo_Civegra is offline
  • Ask a Question
Question Title:
Description:
