2009 Accord Coupe XM......
My coupe is 3 months old and I've had an interesting problem with the XM radio. On two occasions the audio output (sound) stopped. Channel and other info was displayed OK. All other functions such as FM radio, CD, etc worked OK. Turning off the audio system and back on did not affect the problem. Turning off the ignition and then back on restored the XM audio output. The dealer service dept has a call into Honda but I thought I'd post here to see if others have experienced the same problem. Thank you
In a Junkyard near you.
Re: 2009 Accord Coupe XM......
On the Odysseys we had a problem with the DVD cable causing similar symptoms.
Usually with the XM radio it ends up being the XM unit itself. I'm not sure but I think that one is in the trunk again.
Andrew T.
06-13-2013 12:58 PM
GGAccord
03-19-2007 08:08 PM
Lamebirdy
07-20-2004 11:34 AM
