Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Trunk won't open from inside latch
Old 03-27-2010, 08:49 AM
PowerUser's Avatar
Default Trunk won't open from inside latch
I locked my trunk when I took it to the shop to get some new tires put on the car. when I unlocked it it didn't "unlock". I tried multiple times to lock then unlock it again to no avail.
Anyone here know exactly what the problem is?
My key still works fine to pop the trunk using the trunk button.
Old 03-28-2010, 10:12 AM
TRIAL USER
burnRubber's Avatar
Default Re: Trunk won't open from inside latch
Just to clarify, the trunk won't unlock when you use the lever by the driver's seat?
Old 03-28-2010, 12:17 PM
90sedan's Avatar
Does the key turn in the lock cylinder? If not, you may need to "re-key" it as the tumblers are too worn, or your key is.
If it does turn but doesn't unlock the trunk, remove the trim piece and inspect underneath the lock cylinder. There should be a white plastic tab attached to the bottom, it turns when you turn the key and it blocks the latch release when its in the lock position.
Old 03-29-2010, 11:22 AM
PowerUser's Avatar
Correct.
The key turns fine in the keyhole. It simply won't unlock the lock. I'll have to take a look at the plastic tab over the next couple of days. thanks.
Old 03-29-2010, 01:47 PM
PowerUser's Avatar
Fixed.
Thanks for the help
daniel reich
Acura TL, RL & ZDX
09-13-2017 03:37 PM
VTECROAR96typeR
Honda Civic (2001 - 2005)
15
11-24-2008 11:37 AM
Boricuanology
05-28-2007 01:48 PM
GuCCi_GSR
05-20-2007 11:43 AM
Hcivic88
01-11-2003 08:44 AM
Quick Reply: Trunk won't open from inside latch
