2007 accord help?
2007 accord help?
Ok,,again,,2007 accord,,only drivers side window works,(power windows),.,.I've gone through the DIY,,a couple people suggested trying several things:check motors,check each switch,,check master switch,and there's also a 50amp fuse under hood that says power window,,it's ok..I've asked on here and 2 other forums,,everybody avoids my main question,,,Don't mean to sound like a smarta** or rude but the only thing i need info on is this: There are "4" individual fuses under the dash for each window,each one specifies:LF,LR,RF,RR....the only one of these 4 fuses that have power is the only one that works(LF)drivers side front...To specify,,There is no power whatsoever to the other 3 fuses,either side of post,,,,,,,,,,,THE QUESTION is why???where do these 3 fuses get power from,,obviously seperate from the LF power source,,,Anyone please,,this thing has beat me and 2 other forums up,,,any thoughts,THANX
Re: 2007 accord help?
For someone who wants to be exactly correct on grammer and puncutation? It is PUNCTUATION I think is it not sir??? Do you not use capitol letters at the beginning of a sentence?Gotta?? or got to??? would it not be: I would have to admit? And if you need to be so precise about everything, make sure you correct johnnyKash,.,/,.,/,.,/,.you like all those symbols?? How about Johnny C not K Cash !!!!!!!!!!!!!!!! Sooooo, i simply came to ask a question, I didn't realize I would get a grade on how i asked or if i correctly PUNCTUATED. I think it's something about throwing the first stone,,of course your heiness could probably correct me.,.,.,.,.,.,.,.My username as i know you can see is tng6664,, if your only thing to do is check grammar and PUNCTUATION, check to see if it's me B4 you read and get your panties in a wad. It's a forum for questions not school sir. Don't mean to offend anyone here,, but lighten up fella. All the periods and comma's here are intentionally just for you SIR.
Check all of the under hood fuses. Power goes from the battery to that fuse block first before going to the inside fuses. Did you find a copy of the wiring diagram? That should show how power is routed.
Edit: Forget the fuses. Got a diagram. If it's not the relay then it could be the driver's master switch or the wire from the relay to it as the driver's switch provides a ground for the relay.
idumpwitmy12gaugepump
Audio / Security / Video
05-22-2008 07:18 PM
rival12
04-07-2004 08:02 AM
