Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
leaking water from under?
Old 12-23-2009, 01:21 AM
dleccord's Avatar
Default leaking water from under?
my accord leaks water every time i turn on the fan or the heater. the water leaks even when i dont use the AC. is something wrong with my car?
Old 12-23-2009, 02:55 AM
In a Junkyard near you.
Ross 2.0's Avatar
Default Re: leaking water from under?
Might have a leak in the cowl area somewhere. Where does the water leak from exactly?
Old 12-23-2009, 12:13 PM
dleccord's Avatar
i want to say the tube protruding out under the passenger's leg.
Old 12-23-2009, 04:05 PM
Ross 2.0's Avatar
Ahh still a clogged drain tube then. Even though the a/c isn't turned on the compressor still runs on defrost settings and is removing humidity from the air.
So if you clean the drain tube you should get a nice bath and fix the problem.
Old 12-23-2009, 06:21 PM
dleccord's Avatar
how do i clean the drain tube? what do i have to remove?
Old 12-23-2009, 06:40 PM
soon2bdropped's Avatar
underneath the car black rubber hose. blow compressed air into the hose with a blowgun.
HondaAccordTdR
08-31-2008 02:51 PM
Revolver123
Honda Civic (2001 - 2005)
06-14-2008 05:01 PM
plainburg
07-14-2006 07:19 PM
pcorad
07-04-2005 08:51 AM
OgunplayGSR
07-12-2002 10:12 PM
Quick Reply: leaking water from under?
