2006 Honda Accord Radio Problem
Well yesturday I changed the headlight bulbs and in order for me to get to the socket I had to remove the battery to get my hands in there. I have the radio code already which I recieved from Honda Canada. When the radio code message appeared I hit the 2 preset buttons and the power button at the same time then entered my radio code but it still wouldn't tell me that it was correct in a way. But when I hit the preset button 2 the radio went on but would only stay on for just a few mins then it would shut off, I then have to hit those same preset no's agian and the radio would work again but only for a few mins.
Any ideas on what could be wrong? I have searched the web on it and somewheres it says to check the no. 11 fuse?
I have an appoinment to get my block heater w/ sensor this week sometime but i'd rather try to fix the problem myself if it isn't major.
help!
help!
Re: 2006 Honda Accord Radio Problem
I don't know if i'm being too much of a nag but would anyone know how to point me in the right direction on where I can find information on this problem?
It's for a 2006 Honda Accord EX 2 Dr. 2.4L with something like 100k
My Name is Nobody
Your not being a nag, I just dont know where to begin. I know radio codes make your beats live again... but live for a few minutes then shut off?
hmmmm
someone else will chime in soon
hmmmm
In a Junkyard near you.
#1 you replace the bulb through the wheel well, not behind the battery.
#2 unhook both battery cables and touch them together for a few minutes, hook it up and try again.
alright, well ill try that....seems though that i replaced the bulb behind the battery, wheel well for some reason wouldn't open up for me after taking off the plugs :S
ill give'r a shot later today or have the shop look at it when i go in for my appointment.
thanks
thanks
