2006 Honda Accord Headlight Help!
Yesterday my passenger side headlight went out. I went and replaced it with the new bulb this morning but it still wouldn't work. I checked the connector and it's not getting any juice but all the fuses are fine, has anyone come across anything similar or have any suggestions on why it still wouldn't be working??
I'm certainly not a mechanic but I figured the bulb replacement would be an easy fix and I'd like to avoid the dealer if at all possible.
My Name is Nobody
Re: 2006 Honda Accord Headlight Help!
you're going to need to track the line from the connector back. I would estimate that it's right at the connector itself. make sure all pins are seated correctly.
Should I try cleaning the connector or shave the wire to test it?
edmedina71
10-06-2017 08:18 PM
nausicaa
10-23-2008 05:00 PM
