Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Accord Hybrid Loss of Power/Stalling
Old 08-10-2013, 02:03 PM
ender44's Avatar
Default 2005 Accord Hybrid Loss of Power/Stalling
My 05 honda recently developed the problem of losing power and eventually stalling out. When it loses power I can't get it to go over 5mph and within a minute or so it will stall out all together.
I went and got the codes for the check engine light when it came on the codes were:
P2197 and P2195
Definition - AF sensor signal stuck lean- 21
Probable cause
1) Open or short circuit condition
2) Lean Air fuel ration-vacuum leak. low fuel pressure
3) failed AF sensor
I replaced the AF sensor on the car, but the problem has persisted. I went again to get the codes and the second time I got this code:
P0420
Definition - Catalyst system efficiency below threshold bank 1
Probable cause
1) A/F ratio concern
2) Air leak near H02S (Heated oxygen sensor) Bank 1
3) Ignition system concern
4) faulty catalytic converter
Now i've check out the air hose connected to the intake and there is a good size crack in it. The codes leave me to believe that the A/F leak maybe caused by that. I'm planning to replace the hose but I fear it may be the catalytic converter.
Has anyone else experienced this problem or know how to fix it?
Old 08-10-2013, 02:16 PM
timing_chain's Avatar
Default Re: 2005 Accord Hybrid Loss of Power/Stalling
Improper burn of af mean your cat could be broken also. Improper burn clogged cat.
Teman62
06-29-2019 09:27 PM
onefootinhell
11-29-2011 12:25 PM
mextera
06-28-2011 11:14 PM
wky
03-23-2009 08:06 PM
vtec25
05-15-2006 02:07 AM
Quick Reply: 2005 Accord Hybrid Loss of Power/Stalling
