2004 Honda Accord (V6) air conditioner problems
Hi again, I also have a air conditioner problem along with the dimming of lights.
I just recently refilled my air conditioner with Freon and right after I filled up the low end, I heard a few short spurts of air coming from somewhere in the engine. Almost like I pushed in the low end line to release some Freon. This happen a few times and just stopped, but I could not see where it came from. I thought it might have been a leak or something in the lines, but it was just a few short spurts and the air is still cool, but not like it should. I followed all the directions on the can and yes I waited until the clutch turned on to start the filling process. Help again please to anyone who knows what might be the problem. I was also thinking it happen due to an over fill?
Bob
Bob
Re: 2004 Honda Accord (V6) air conditioner problems
most likely the valve on the compressor.you most likely overfilled the system.the system should be properly drained and recharged with the correct amount of Freon.Also the system should be tested for leaks and if any are found they should be repaired.
Atalbot20
03-31-2018 09:32 AM
debbieyakiwchuk
07-27-2017 04:27 PM
