2004 Accord EX 4Cylinder engine trembling a little
So I noticed that over the years my 2004 Ex Accord has started trembling when stopped at a light, for example . More so with the A/C on.
I have used fuel injector cleaners before and haven't noticed any difference.
I have cleaned out the throttle body before. Wasn't too dirty.
What could cause this? I have changed out the Spark Plugs before and they looked great.
Thanks for any input.
Re: 2004 Accord EX 4Cylinder engine trembling a little
have you checked your engine mounts or exhaust mount?? you might have a bad engine mount. as for the exhaust usually the mount for the a-pipe breaks
Wow, really? On a car that's only 5 years old? I work on all my cars, but for the mounts to go bad this early is a sign of inferior parts.
Was there ever an issue with the mounts on this generation of Accord?
Thanks
Thanks
So anyone else have any input on this or is it pretty much the motor mounts?
Thanks.
Thanks.
hey im new to this site an im experiencing the same problem of vibrations .....i have change all motor mounts, changed the plugs and still the problem is there ......also the car was in an accident b4
Thanks.
Thanks.
There was a Honda TSB on the motor mounts, etc. for the 2004 Accord 4 cylinder causing engine vibration in gear, which is probably why it was already mentioned previously as a possible cause.
BlaccPlasticc
08-29-2013 12:49 AM
