2004 Accord Electrical or Transmission problems
2004 Accord-142,000 miles - Sporadically, after the car warms up (20 min highway driving) when I turn on the blinker or step on the brake the car goes out of gear. The gear indicator light goes off and there is no power for a couple seconds. The light then comes back on and power is restored. If the power goes off from the blinker action and I am accelerating the RPM shoots up. I can also go days without this happening. I have had it to 2 garages and they cannot duplicate. It started after an automatic transmission fluid flush.
Ideas of cause?
Ideas of cause?
Re: 2004 Accord Electrical or Transmission problems
Assume all but it just for a second so I am not positive. I do not feel the steering getting hard to use as if the car were off.
Also just picked it up from a Honda dealer. They could not duplicate so I just had to pay to get it back still broken! It did it 4 times on the way home from the dealer!
First, I would have the battery tested. A weak battery can cause communication errors. If you're not lucky you could have a bad ECU. Is the D light in the dash flashing or going out or coming on when it shouldn't be? I can't believe the dealership can't figure this out. I guess they are as lazy as the guys working at my local dealership. Good luck with it.
chris031591
01-09-2013 05:21 PM
