(2004 Accord Auto To Manual Swapp) Now Car Wont Start
Hi I Just Did A Conversion On My 2004 Accord 2dr I Have Everything The Same From A Reg Manual Accord Besides The Harness Every Site I Looked At For The 2003-07 Accord Mt Swapp And 03-07 Tsx Said The Harness Can Be Re Used I Did Have The Auto Ecu In When I Tried Starting The Car The Switched It To Then Manual One, I Know Ther Car Will Have To Be Rewired Because The Neutral Safety Switch But I Dont Know The I Would Have To Ground,Without Me Knowing What Wires The Car Say It's In Drive And Wont Start And The Key Will Not Come Out Can Anybody Help I Dont Know The Colors Or Anything.
IF ANYBODY HAVE ANY INFO ON THIS OR HAD A PROB LIKE THIS PLEASE HELP ME OUT
Thank You
Thank You
Re: (2004 Accord Auto To Manual Swapp) Now Car Wont Start
Wow, dude. Punctuation may more helpful here! Whew!
When you swapped out the ECU, did you have the battery disconnected? Pulling an ECU with the battery connected can do very bad things to ECUs. They are energized by the battery, when the car is off.
If you moved the whole wiring harness, then hopefully you moved all the sensors for the brake and clutch pedals. The ECU takes signals from all of those sensors.
you need to reprogram the ecu for the imobilizer to recognize the key and the pcm. I bet you the little green key on the guage cluster is flashing when you try and start it. Also the auto ecu will be fine. You can also use the auto trans harness. You just need the speed sensor pluged in and the car should run after you reprogram the keys and imobilizer.
old thread, but I am having start problem... I have a manual ECU, removed the immobilizer chip, which is supposed to work.. the key light wasn't flashing when I first changed ECU.. it is now.. any ideas? I jumped the safety switches in old AT shifter... all continuity checks seem good, no start power to solenoid..
CD8coupeSiR
07-15-2006 01:06 PM
cwhonda1
06-06-2006 08:48 PM
i97supratti
05-15-2005 02:19 AM
