Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord Drive Axles
Old 08-21-2010, 06:58 AM
gaussian528's Avatar
Icon2 04 Accord Drive Axles
How can I go about determining which drive axle is causing vehicle vibration. I replace both with rebuilt axles. Vibration went away for about a month....now its back.
Old 08-23-2010, 02:28 PM
cate)'s Avatar
Default Re: 04 Accord Drive Axles
from experence rebuilt axels for 03 and up absolutely will not work they will vibrate. Let me guess it vibrates on accel and is fine when you let off the gas. I know this is probably right so now you need to go to anvanced and give them pos back and go to honda and by new oem axels. I can also tell u that on a 06 five speed pass side axels is about 550. to 600 bucks so take some vasoline with you when you go. And you can diag by determining which way the car pulls when accelerating if no pull then it is both. If it is automatic it is probably the driver side.
Old 08-23-2010, 05:19 PM
thefacta's Avatar
Hope its not your motor mount(s)!
Old 08-24-2010, 04:51 PM
Right!!!! It vibrates around 25, goes away, then at 60 and goes away. It always goes away after I let off the gas. I was told that it might be my tie rods. When I brought it to Honda initially, they said it was the axles and wanted to charge me $600+ to fix.
Old 08-29-2010, 12:29 PM
Turns out the passenger side (inner joint) has a little play in it. There is no play on the driver side (inner joint). Do I need to replace the axle?
VDM_DC2
Suspension & Brakes
11
10-28-2009 12:28 PM
cornflake-dc2
12-21-2007 06:23 PM
Fly1865
09-24-2006 05:29 PM
Log4n
08-31-2003 07:22 AM
Quick Reply: 04 Accord Drive Axles
