2004 6 Disc CD Player jam
hey guys,
Yesterday my player was switching a cd and it ended up jamming. I pulled the fuse and resetting the player to see if that would work but that was a no go. Anyone have luck in fixing this?
Re: 2004 6 Disc CD Player jam (Matt00)
Well guys i fixed it. I pulled the whole Radio/NAV unit out. You have to take off the two side metal brackets and pull out the Radio/CD Unit. I unscrewed all screws around the disc changer tray(bottom). Unscrew the face of the slot loader for the cdrom and there is a metal piece going through the pcb board, you have to straighten that out to get face off. One the face is off you can pull the disc changer tray out. My disc was on top and popped off the middle piece that spins the cd. I moved it back into the sleeve part. When putting everything back together make sure the ribbon cable to the radio from the cd unit is connected. I hooked everything back up, put my radio code in, and everything is working normally.
xkrntamax
Audio / Security / Video
12-25-2006 06:27 PM
