2003 honda accord Transmission Problems? - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 03-10-2017, 11:20 AM   #1
Icon5 2003 honda accord Transmission Problems?
Hey guys i have a 2003 honda accord, I replaced my starter recently and the intake gasket manifold.
And after i was done my dad forgot to tighten the intake bolts so i had a intake air leak for a day or two.
After tightening them back my transmission started acting up. I don't have any codes that pop up about the transmission from the obd reader, only code is P0420.
But my problem is when it shifts into third gear occasionally it will shift out of gear, and depending on the pressure on the pedal it will rev in rpm and when i let foot of pedal it will shift back into gear.
It will only happen after third gear others it shifts fine into every gear. Also when i start my car in my dash i here a ticking like sound that only happens in park, Brand new problem that popped up after my intake air leak. And it will go away once i move it into reverse, neutral, drive etc...
I dont know if it is related to my shifting problem.
If you guys can please help. I personally don't think it is my transmission, i believe it is something smaller.
Please let me know ur opinion.
Vcballer is offline   Reply With Quote
Botched clutch replacement, or something else? alowe336 Acura RSX DC5 & Honda Civic EP3 13 10-08-2017 09:24 PM
92 accord wandering clutch pedal feel DCRB Honda Accord (1990 - 2002) 6 10-06-2017 12:39 AM
89 CRX SI, Jacking when turning tight with aweful noises and popping out of gears 98Mystique2 Honda CRX / EF Civic (1988 - 1991) 3 04-25-2017 06:44 AM
2012 Accord SE Transmission Leak jits1980 Honda Accord & Crosstour (2003 - 2012) 0 02-03-2017 09:24 AM
Type R transmission; 3rd gear engagement issue ONe21 Transmission & Drivetrain 5 02-03-2016 04:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
