2003 Honda accord HELP PLz
2003 honda accord : So this weeknd i installed a Hi-lo converter to the stock factory wiring harness behind the stock radio so i could run an amp...while doing so i hooked up the Remote wire for the amp to the IGNITION wire where the radio harness was... red/yellow wire.. so aafter bout 5 mins i guess the fuse burnt or something..cause now my igition wire on the wirign harness does not get power, along with the cigerrete lighter things... i checked the fuses under the dash n engine..cant seem to find it..so my radio does not turn on unless i ghetto rigg a 12 volt constant wire to that wire with a switch or something...how can i fix this problem..is there a fuse some where? any help will be appreciated..thnx
jromulo
08-19-2007 11:10 PM
