Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Cause for v6 05 accord timing belt slip off?
Old 03-22-2014, 06:21 PM
kenpoed's Avatar
Default Rod cracks after reman
Had to alter this post because after initially thinking the timing belt slippe doff after a full reman on an 05 v6 accord, it was actually a rod that cracked.
What could have caused this? Is this sloppy work on the part of the engine rebuilder or just bad luck???
Old 03-22-2014, 07:56 PM
BLKFLSH's Avatar
Default Re: Cause for v6 05 accord timing belt slip off?
Wow, that blows. I'm glad I changed my tensioner. How many miles were on it?
Old 03-22-2014, 08:24 PM
johnsc2235's Avatar
I always replace the tensioners because of this reason...
Old 03-23-2014, 06:15 AM
rodondoaccord's Avatar
I guess this answers my question if I need to replace my tensioner...
sorry bout the rotten luck
Old 03-24-2014, 08:14 AM
furious94ls's Avatar
When you had the engine rebuilt did you use an OEM belt, and tensioner?
Old 03-24-2014, 02:07 PM
kenpoed's Avatar
No he did not
Old 03-26-2014, 03:41 PM
That's most likely the reason. Spend the money and use OEM parts.
Old 03-27-2014, 01:54 PM
DCFIVER's Avatar
Originally Posted by kenpoed
Had a timing belt tensioner freeze up on a timing belt with only 20k on new belt but old tensioner.
Engine totally remanned and after a couple hours the new timing belt slid off AGAIN ruining the engine.
What could be causing this?
Luckily it is covered but I am starting to think this car is jinxed. Yes, it is a reputable engine shop.
Help!,,
Ive done dozens of Honda V6 engines in that model year range,and ALL of the tensioners were leaking or starting to leak, including the one on my own mothers car.....
Old 04-02-2014, 03:48 AM
kenpoed's Avatar
actually, found out it was not the belt, the Rod broke and cracked the case. Reman guy has to do everything all over again.
Sloppy work or just bad luck???????????
msrief
03-17-2018 08:50 PM
B18C5-EH2
08-07-2015 06:41 PM
T3KNiQe
12-11-2008 10:29 AM
e_r_i_c_
04-22-2003 07:02 PM
dclub01
03-19-2003 08:34 AM
Quick Reply: Cause for v6 05 accord timing belt slip off?
