2003 Accord Makes Noise on Cold Morning - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 12-03-2009, 12:03 PM   #1
DaMenaCe's Avatar
Default 2003 Accord Makes Noise on Cold Morning
Hello Everyone,
I am having this "Noise" issue with my car since last year. However, it went away over the summer when the weather was warm, but as the weather is starting to get cold again my car makes this ODD noise in the morning towards where the Belt is. i mentioned it to a technician at the dealers but i couldn't explain the noise as this only happens when the car is cold, by the time i get to the technician it wasn't making any noise. This started happening after they chance some sort of a belt. Also there is some weird noise every time i turn my wheel and again this only happens in the morning or if the car has been sitting in cold for few hours or so. i am posting a link to a video which might give you a better idea of this "noise" if any of you guys might know what this is, please let me know so i can either take care of it myself of explain it to the technician.
http://www.youtube.com/watch?v=go1LZ...layer_embedded
DaMenaCe is offline   Reply With Quote
Old 12-03-2009, 12:13 PM   #2
redbull-1's Avatar
Default Re: 2003 Accord Makes Noise on Cold Morning
Check the power steering fluid level first.
There was a TSB regarding this. An o-ring needs to be replaced. Usually air bubbles or foam is in the power steering fluid reservoir. I'll see if I can get you more info.
redbull-1 is offline   Reply With Quote
Old 12-03-2009, 12:18 PM   #3
redbull-1's Avatar
Old 12-03-2009, 02:24 PM   #4
DaMenaCe's Avatar
hello RedBull-1 thank you for you Help... now this will take care of my issue of moaning noise when turning the steering wheel when the engine is cold.
now do you what could be the reason behind the hissing noise i hear every time i turn on the cold engine?
once again thank you for the researching and posting the link to the thread i really really appreciate it.
Old 12-03-2009, 02:42 PM   #5
redbull-1's Avatar
Take care of the power steering o-ring first, then see if the hissing still exist. Better to isolate each problem and fix each one separately first. That way you wouldn't be throwing time and parts at it unnecessarily.
Also, are any accessories turned on when it is cold, e.g., A/C , etc.?
Old 12-11-2009, 11:28 PM   #6
I think I hear a power steering pump thats low or empty on fluid...
I say listen to redbull he knows what hes saying.
HondaFan6975 is offline   Reply With Quote
Old 04-13-2010, 09:44 AM   #7
I'm having the same problem, I gonna fix this weekend.
Great thread. Thanks guys.
da993 is offline   Reply With Quote
Old 04-16-2010, 08:18 AM   #8
Sounds lie a bad bearing set to me.
grover432 is offline   Reply With Quote
Old 06-21-2010, 02:24 PM   #9
I have the exact same problem with my 2003 Accord EX....anyone have the fix for this.....and why it only happened in the cold morning? Please, help? Thanks in advance!
BradJohnson10 is offline   Reply With Quote
Old 06-21-2010, 02:42 PM   #10
crazyheadrush's Avatar
The Belt May Have To Much Tension. 2 Tight. But after it heats up it expands a bit.
crazyheadrush is offline   Reply With Quote
Old 06-21-2010, 04:00 PM   #11
BLKFLSH's Avatar
BLKFLSH is offline   Reply With Quote
Old 06-24-2010, 09:47 AM   #12
Thank you so much for the great info...I will talk to honda service dept, and will see what they said regarding this issue.
Old 01-03-2012, 08:37 PM   #13
My 2003 Honda Accord just started making this noise too. Thanks everyone for the posts! They are extremely helpful to me as a woman trying to figure out car problems on her own.
BrennaJ is offline   Reply With Quote
Honda CR-V 2006 slow to crank randomly slamarre Honda Element & CR-V 2 12-30-2016 12:18 PM
2000 Civic SiR Starting Troubles StuG_Lyfe Honda Civic / Del Sol (1992 - 2000) 1 09-28-2014 07:38 AM
2001 Honda Accord metal grinding fluturm Honda Accord (1990 - 2002) 7 01-24-2011 09:18 AM
Suspension noise in cold weather? lunarone Honda Accord (1990 - 2002) 8 12-07-2006 11:58 AM
Grinding Noise in Low RPM .. might be clutch chatter? Crafte Tech / Misc 0 03-17-2006 09:10 PM
Tags
2003, 2006, accord, accura, car, cold, honda, installation, make, makes, moaning, mornings, noise, pictures, power, powers, steering, stering, tl, v6, weird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
