2003 Accord locking problem
Yes I know, another Accord problem. It's an EX V-6 automatic. I have searched and tried some of the tests done by other people, it didn't help. So here's my problem. My door lock/unlock worked just fine this morning. Using the key fob and interior button, as well as my trunk opener. But as of a few hours ago nothing will. I have to manually push the locks down and can only get into my trunk with a key, the handle doesn't even work. The windows work perfectly. Fuses were good. Any help is highly appreciated and thanks in advance.
Re: 2003 Accord locking problem
Also the dome lights don't work with the doors, but do manually. The dash light that shows when doors are open works just fine.
Think you might need a new battery for the remote?
This is probably the issue with the map lights.
Dome Lamp Fix on 2006 EX-L - Drive Accord Honda Forums
You can try the repair, or buy new switches here.
http://www.mouser.com/ProductDetail/...fYnNfLHA%3d%3d
I already replaced the remote battery. I programmed the key also. Disconnected the battery and touched the cables for 15-20 minutes like other people were told.
tan cong
08-20-2008 06:44 AM
