Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 V6 with DTC P0506
Old 04-28-2008, 07:15 PM
fuzzballcadillac's Avatar
Default 2003 V6 with DTC P0506
My 03 V6 coupe has the CEL on and when I scanned it two codes were shown. P0506 generic Idle control sytem Low idle, and a manufacture specific code 126-02. Does anybody know what I need to fix the problem? The car has been stalling on occasion.
Old 05-03-2008, 01:06 PM
MustangLX6.0's Avatar
Default Re: 2003 V6 with DTC P0506 (fuzzballcadillac)
Does it have an aftermarket intake that code indicates lower than expected idle. Check for any blockage in the intake track and also the throttle body for blockage
DTC P0506: Idle Control System RPM Lower Than Expected
This is straight from Honda
Remove the intake air duct from the throttle body.
Check for dirt, carbon, or damage in the throttle bore.
Is there dirt, carbon, or damage in the throttle bore? YES - If there is dirt or carbon, clean the throttle body. Also check for damage at the air cleaner element, then go to step 9. If there is damage in the throttle bore, go to step 8.
NO - Check the A/C system or power steering system, then go to step 17.
phelpsj2
11-03-2011 02:35 PM
hondateched
07-25-2009 07:49 PM
fronomo
08-28-2007 03:56 PM
LilManSi
01-26-2004 04:12 PM
Ink00
12-24-2002 01:15 AM
Quick Reply: 2003 V6 with DTC P0506
