2003 Accord 4cyl misfire Code
I just bought this Accord and it had a misfire when I brought it. The check engine light is flashing so I assumed it was ignition coils, spark plugs, or injectors. I did the ignition coil swap from cyl 3(the one that was misfiring) with a different coil from cyl 1 and two and the coil worked fine on both. Even bought new coils and same thing. Got new spark plugs and still nothing. Changed injectors and even checked the ignition coil relay and nothing was burnt. I’m not sure what else to change or where else to look. I haven’t taken it into a shop yet. Just looking to get some suggestions.
Re: 2003 Accord 4cyl misfire Code
How did the old plugs look...Pull new plugs, fouled?
Has it been sitting for a while? (=bad gas still in the system) How many miles? Could need valve adjustment, any valve clatter on startup?
Any ODBII codes?
Any ODBII codes?
Engine was bad. Had to be completely rebuilt or swapped. I went online and decided to buy a jdm engine and swap that in since the cost was much less then a rebuild. Anyone have any experience with buying and running a jdm engine for one of these cars? I was a little skeptical since I know about that Japanese laws and why most cars are low mile but I’m still not 100% convinced.
Alan Castillo
03-06-2018 09:01 AM
Delton333
05-13-2008 08:15 PM
