2003 2007 Accord Airbag ecu
Re: 2003 2007 Accord Airbag ecu
um... Please don't...
what could you possibly need the control module diagram for?
airbag technician by trade, my PROFESSIONAL opinion... BUY NEW.
Yes ok. But I live in Turkey and Eu accord ecu pinout different according to US accord airbag ecu. I buy to new ecu from US, but I can't use this please help me
I dont need to ecu electronic circuit diagram, only need to ecu pinout and wiring diagram
If the airbags have deployed, the SRS control unit (which you are calling the airbag ECU) must be replaced. The internal inertia switch can only be triggered once and then control unit must be replaced. If you are trying to trouble shoot the SRS system malfunction light, it will not shut off until the unit is replaced and system reset.
It Wasn't Me!
1 Post
If I'm reading this correctly his problem is that he bought a new SRS control unit for a USDM Accord and wants to install it in his Turkish (EDM?) Accord. The pinout is different for them and he wants to try to make it work in his car.
Not knowing if the SRS system is the same in both cars and with no way to really check this is a horrible idea which will probably end up costing him even more in the end. If you want it to function properly the SRS system is not a system that should be messed with.
2000Accord5sp
06-10-2005 12:36 PM
