Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
08 Accord V6 running on 4 cylinders?
Old 10-15-2009, 11:38 PM
New User
shaolyn54's Avatar
Icon3 08 Accord V6 running on 4 cylinders?
I have an 08 accord v6. Took it to the dealer today and they said that only 4 cylinders are working. I asked them if it's okay to drive around and they said it was fine. The VSA light keeps popping up for no reason. What could cause it to run on 4 cylinders and is it really okay to drive it around? Please help!
Old 10-16-2009, 08:45 AM
ilikehonda's Avatar
Default Re: 08 Accord V6 running on 4 cylinders?
is the eco light on all the time? the accords have the cylinder mgt for better gas mileage
Old 10-16-2009, 02:18 PM
New User
shaolyn54's Avatar
the eco light is on all the time. the dealer said they have to diagnose the head assembly and they don't know whats causing the problem. they said the "rear cylinder" is not working. i don't know what that means. does an accord have a rear cylinder?
Old 10-16-2009, 05:09 PM
My Name is Nobody
MSchu's Avatar
that diagnosis makes little sense because the front only has 3 cylinders. and since the ignition system is coil on plug, a bank going down is really unlikely.
running on less than 6 ylinders is more than likely a sensor or electrical issue... NOT a mechanical one.
your car is designed to run on less than 6 cylinders, so are you sure the dealer was simply explaining the VCM feature of your car? I doest think he was
Old 10-20-2009, 10:03 PM
New User
shaolyn54's Avatar
just heard from the dealer today and they said some valve seals failed and some spark plugs misfired. they replaced the valve seals, spark plugs and resurfaced the head. could this have damaged the cylinder walls? maybe made some scoring?
Old 10-21-2009, 01:40 AM
NooB
IT'S ME DAVID's Avatar
I dont think valve seals will make it run on 4 cylinders..
Old 10-21-2009, 09:32 AM
fiveten's Avatar
Honda is having problems with their v6 vcm engines. the rear bank valve seals were installed incorrectly and damaged. The spark plugs begin to oil foul and cause misfires. You can get misfire codes and or vtec codes due to low oil / oil pressure. Replacing valve seals is the fix for this problem. A service bulletin will be released soon.
Old 10-21-2009, 09:37 AM
93HoDNA's Avatar
my girlfriend has a 4cylinder one, with a little exteriors mods, should she worry about this kinda of stuff???
Is it only on V6 models??
thanks
Old 10-21-2009, 07:53 PM
redej878's Avatar
actually Honda designed the new v6 engine to shut down an entire bank if there are 2 cylinders missing on that bank, from there the engine bumps up the idle to 1500 rpms and runs only on 3 cylinders.
also it is possible to have a mechanical issue and not have any dtcs.
Old 10-21-2009, 07:55 PM
redej878's Avatar
thanks
we have only seen this on the v6 models. One of those did have scoring on the cylinder wall.
Old 10-31-2009, 03:36 PM
Angels_fall_first's Avatar
i work at a honda dealer and have repaired a similar problem on a 09 honda(had 5 miles on it) odyssey that threw a check engine light and VSA during salesmen test drive with a potential customer. LOL.
it came down to the variable cylinder management hydraulic actuators sticking and making the some of the valves stick open. i replaced the whole rear cylinder head under warranty. (^_^)
VCM can make your V6 engine run on either 3 or 6 cylinders...or....3 or 4 or 6 cylinders. its depends on what version of VCM you have. VCM-I or VCM-II
Old 03-15-2010, 02:52 PM
09V6coupe's Avatar
Bumping this to the top to go with my other thread... Looking to see if there are more occurrences of this in other V6 accords.
The dealership only states that this is a known issue and Honda is investigating. Can the user fiveten please elaborate if they know when a notice for this repair will be posted to the dealers. I do not want to take my wifes car in every few weeks for new plugs. Clearly there is a problem here.
Old 03-19-2010, 02:41 PM
TRIAL USER
bhonda1981's Avatar
it actually does make some sense that its only running on 4 cylinders. 2008's shut down from 6-4-3 depending on what parameters the pcm is detecting. So if its running on 4 cylinders probably has 2 cylinders on the rear bank that are not firing.
Old 03-29-2010, 06:44 PM
Sr420Det's Avatar
I know u guys are speaking of the motor cutting off a few cylinders to save gas but if oil is fouling out the plug and gas is still being injected, i imagine the cylinder walls wont be in top notch condition afterwards
Old 03-29-2010, 07:20 PM
My Name is Nobody
MSchu's Avatar
Why is that... the pistons and rings are completing a cycle no matter if they are firing or not(this actually happens during every four cycles anyway). as a matter of fact I would hazard to guess that a wall and o Ring would last longer without combustion if it was say... being turned over by an outside source.
Old 03-30-2010, 05:10 AM
LPED's Avatar
because if its caused by fouled spark plug that means unburned fuel will wash away the oil on the cylinder walls and can give problems. Also unburned gas going out exhaust is not good for O2 and cats , will shorten there life .
Old 03-30-2010, 07:13 AM
Sr420Det's Avatar
Yes ur an idiot, gas will act as a detergent and clean the hell out of the walls especially with all that heat too. Not only will it **** ur cylinder walls but it will also get into ur oil and deteriorate it. It wont take long of driving like that to completely destroy the properties of ur oil and bearings start spinning, etc... Plus like the dude above me said it will prematurely where out ur o2 sensors and converters. U want gas to fire not wash away the oil on ur walls and trash ur oil.
Old 03-30-2010, 07:24 AM
LPED's Avatar
While what you say is all correct , why the attitude ?
Ed
Old 03-30-2010, 07:26 AM
Sr420Det's Avatar
Cause i hate my life
Old 03-30-2010, 08:11 AM
My Name is Nobody
MSchu's Avatar
I understand how internal combustion works... I know how rings wash out... I know how rings seat.
Oil fowled plugs and a complaint that fuel injection will wash out the rings? come on man, get with the program
VCM works by Disengaging operation AT THE VALVES halting Fuel supply in combination with iVtec. If somehow the vales were locked open, then failure would be more likely... IF
What doesn't make sense with that idea is that if the rocker arm was locked in the OPERATION position... it would just be operating, meaning no VCM mode, just regular 6 cylinder mode
Old 03-30-2010, 01:24 PM
Sr420Det's Avatar
read here
CEL2018
10-04-2018 07:56 AM
kyhusker80
08-27-2014 10:44 AM
mewalke1
10-06-2013 03:28 PM
Quick Reply: 08 Accord V6 running on 4 cylinders?
