06 Accord Stiff/Hard Steering At Low RPM
I have an 06 accord with very stiff steering at low RPM's. (NO Foaming or Noise issues At All) I have flushed out the system with 6 bottles (using the disconnect return hose into a bucket and start engine method).
I then tore apart the pump and replaced all the seals from a kit, the vanes looked good and also replaced the fluid reservoir (incase that little filter was dirty). All to no avail.
From what I have seen from comments here and there are that these pumps were not designed properly and that there may be a better replacement with larger vanes to increase flow but I am not sure how to figure that out. I did buy an A/C delco remanufactured pump but have yet to put it on thinking I would just be replacing a failed design with another one.
Does anyone, know if there was a redesign for the Accords Like The 05-10 Honda Odyssey Had: http://www.urvi.net/forumfiles/SB/A11-039.PDF
And does anyone know if that redesigned Odyssey pump would fit the Accord? They look the same; however tho, the first part numbers are same, but the 3 letters after are different 56110-RAA vs 56110-RGL: https://www.hondapartsnow.com/parts-.../p-s-pump.html VS https://www.hondapartsnow.com/parts-...s-pump-l4.html
Any advice, opinion or flat out dart throwing would be appreciated.
kenhyde87
06-04-2019 11:53 AM
WillySLC
05-31-2012 01:56 PM
sodajerk
12-30-2007 11:28 PM
