Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
06 Accord Fuel Cap ?
Old 01-21-2010, 06:51 PM
gettin it's Avatar
Default 06 Accord Fuel Cap ?
Ok, i have a 06 Accord. Now i ran the car low on gas until the fuel light was on, but it never died or anything. So i made it to the gas station and top off. Good to go right? Wrong, i look down and see the writing, check fuel cap. I checked the cap and it was tight. SO i turned the car off, took the cap off again, and replaced it. Started the car, samething. I looked at the rubber piece also in the cap. It looks to be fine also. The car runs fine and everything, but would like to get rid of the fuel cap issue. But i could take off the battery cable and leave it off and that will clear it right?
Old 01-21-2010, 08:24 PM
PilotOnDubs's Avatar
Default Re: 06 Accord Fuel Cap ?
i think if you drive it through a few drive cycles, the system will see that its tight and clear the light...im not too sure on that though. if not, you can have the dealer clear it for you
Old 01-22-2010, 06:38 AM
gettin it's Avatar
Or i can pull the postive battery cable and leave it off for a second and reset it that way also correct? But then ill have to re enter my radio code.
Old 01-22-2010, 07:01 AM
im not sure if that will reset the fuel cap indicator...but its worth a shot, as long as you have your radio code and all
Old 01-22-2010, 03:07 PM
be professional
Targa250R's Avatar
No need to pull a battery cable. If the fuel cap isn't faulty and the EVAP system monitor isn't detecting any leaks, then the pending code will clear on its own within a few trips. If there is indeed a problem, then the Check Engine light will be turned on the next time that the EVAP monitor runs.
Old 01-24-2010, 10:59 AM
K24power07's Avatar
Unplugging ur battery wont help, it will only reset the computer and if there is a problem it will show up again after reset is finish , so ull just be delaying the issue...
Old 01-25-2010, 02:51 AM
gettin it's Avatar
I know it wont help. But i wanted to see if there is a problem, or i just had a loose cap. I think it went away, ill check later. Thanks guys
Old 01-25-2010, 06:07 AM
K24power07's Avatar
I forgot to mention this, my wife has a 04 crv and the same thing happens to her when she gets gas not all the time but once in a while the light goes on, and after a couple of trips it goes away , but only when she gets gas.. it doesnt seem like a major problem but i can see how it gets annoying to some people..g/l
Old 01-26-2010, 03:40 AM
gettin it's Avatar
Ok, good info guys. And the light cleared up by its self. Thanks
GreatZero
10
01-26-2016 04:29 PM
jeebus520
07-09-2010 10:15 AM
rjp
08-20-2009 12:10 PM
Mike813
Honda Civic (2006 - 2015)
02-13-2008 04:17 PM
civicb16eg
06-29-2007 12:08 PM
Quick Reply: 06 Accord Fuel Cap ?
