05 Honda Accord Coupe 2.4L Transmission and other help
I currently own a '05 Honda Accord Coupe 2.4L MT K24A4 and i am looking to swap the stock clutch out for an Exedy Stage 1 clutch and flywheel. I am currently using Redline MT tranny fluid and I am inquiring as to if i should stick to that fluid for the new clutch or should i swap?
Another note would be if anyone happens to know of a good place to get a set of eyelids for my headlights. been searching all over the internets for them but i have not seen a pair made for the G8 accord.
Well thank you in advance for any help that you may provide.
Re: 05 Honda Accord Coupe 2.4L Transmission and other help
Unless you are making more than 50whp over stock there is no need to upgrade the clutch. If it's worn out get the EXEDY OEM replacment kit. It's more than enough for bolt ons.
Also, you have a 7th gen Accord, I'd look on ebay, or amazon for the eyelids.
Thank you for the correction. I didn't even notice that I said 8th Gen. lol. I have scavenged both Ebay and amazon with no results except for 5th gen's.
Okay once again.. I fail. Just found them on ebay. Thank you again for all of your help. Do you have any advice on the Tranny oil?
atom1
11-18-2010 08:23 PM
